unplug the 2 connections from the ptu, clean them up and use some dielectric grease on connection. Do the same for all of the adapters leading to the PTU as well as the CAS. I has this same problem and it ended it once dielectric grease was used. If this doesn't fix it, I bet its dead injectors.
